VAF Forums
-   Interiors (https://vansairforce.net/community/forumdisplay.php?f=89)
-   -   Any suggestions for cleaning harnesses (https://vansairforce.net/community/showthread.php?t=114059)
walkman 06-13-2014 10:34 AM
I have the big ole clunky Hookers front and rear, with the ratchet adjustment. Love 'em, but they've gotten pretty filthy over the last decade. The rear one is thoroughly oil soaked in parts.
Any suggestions to clean them? I can't just remove and stick in a washing machine with all that ironwork on them.
Low Pass 06-13-2014 10:40 AM
Strong detergent (Purple Power), scrub brush, water rinse, dry?
az_gila 06-13-2014 10:55 AM
No strong detergents - use Woolite.
glenn654 06-13-2014 09:05 PM
Hand wash with mild soap (woolite is good) and can use a soft brush sparingly, you don't want to abrade the belts and rinse thoroughly.
Let air dry inside or at least out of the sun.
Glenn Wilkinson
Ironflight 06-13-2014 09:26 PM
Did you say "oil Soaked"? If that is the case, I'd seriously think about getting them re-webbed. Webbing does not take kindly to oil - in the climbing world, I'd get rid of anything that had gotten oil on it.
erikpmort 06-13-2014 09:29 PM
Timely post. A coworker lost his cookies in my plane a couple weeks ago and the seatbelts were lucky the only casualty. They stink.
walkman 06-16-2014 11:26 AM
Yes. Specifically smoke oil. Its mostly in the lap pad, but one side of the webbing is as well. What is the issue with webbing and oil that makes it so bad?
larosta 06-16-2014 01:03 PM
http://www.dropzone.com/safety/Gear_...abric_542.html
http://www.pilotoutlook.com/parachut...ing_procedures
http://www.cpsworld.com/tech_pdfs/manuals/PUB-28-R3.pdf
rocketbob 06-16-2014 01:59 PM
I've washed them in a dishwasher.
BillL 06-16-2014 04:02 PM
Yep - In earth moving equipment, safety belts are required to be replaced every three years by law (or lawsuit).
Call Hooker.
