ADS-B receiver recommendation for Android
Based on actual, firsthand experience, can anyone recommend an ADS-B receiver that will work with my Nexus 7 tablet and Avare? I'm mostly interested in NEXRAD and METARs; traffic is not a consideration.
Thanks, Joe |
my installation
I have a flight data systems pathfinder remote adsb receiver and last weekend I bought a nexus 7 while visiting our kid in NH. I installed avare and flew back to TX on Monday and Tuesday and was able to view the adsb radar okay. Since I am new to avare I did not figure out how to view metars until after I got home so need another flight to check on merars.
another comment
If you checkout the link below to our Spot tracking map you will notice that we
did not take a direct path home because of all the stormy weather across our route. So we had alot of weather on the adsb radar to view on the Nexus 7. I was impressed with the Nexus 7 for use in the RV7a. |
Joe, I say hold off on buying an ADS-B receiver for use with Avare. I have been in the very early stages of testing the use of a RTL2832 software defined radio for use with Avare. This USB device is $10. So far its working well and soon Avare will have support for connecting to this device to receive traffic. Eventually weather will be a part of this.
But if you have to have one now, the Dual is what works with Avare. |
The company's web site leaves plenty of unanswered questions so I'll really be interested in your further reports. Thanks, Joe |
But I'm a bit of a skeptic: I used a similar DVB-T SDR to do ADS-B tracking on an old XP PC and it brought the processor "to its knees" with the CPU-intensive software. (IIRC the PC needed to do DSP on the output of the DVB-T.) My Nexus 7 processor seems even less capable. But I hope it flies and can't think of a better innovation for EAB avionics. I'd appreciate hearing more about it, Bob -- maybe even participating in the test. Thanks, Joe |
SDR devices/Pathfinder ADS-B
Just wanted to add my 2 cents here.
The $10 USB SDR units work great, however, they are not capable of receiving any ADS-B weather (text or graphic) since they only work at 1090MHz. All they will receive is an incomplete traffic picture of a few aircraft equipped with 1090 Mode ES transponders (mostly big iron and a small but increasing number of GA panes). All ADS-B weather products are transmitted on the UAT frequency of 978MHz which will not work with the inexpensive SDRs. @Joe Dubner, Please call or email us any time if you have questions about the Pathfinder ADS-B receiver. Chuck Newman Flight Data Systems VAF Advertiser 831-325-3131 |
-- Joe |
| All times are GMT -6. The time now is 10:17 PM. |
