VAF Forums
-   RV-12/RV-12iS (https://vansairforce.net/community/forumdisplay.php?f=73)
-   -   Right Side Wing Connector (https://vansairforce.net/community/showthread.php?t=112388)
jsenft 04-26-2014 08:37 AM
Right Fuselage wing Molex connector, I don?t see where the Yellow/Blue wire should be inserted into the Molex connector. I know it goes into this connector because it comes with the pin already attached. Help.
Terrybrd 04-26-2014 07:26 PM
I think what you are are looking for is on page 31B-18 Figure 2.
It shows the ES-00078 connector Male with Yel/Blu going to pin 4.
Check it out to make sure that is what you are looking for.
Terry
