VAF Forums
-   -   Ethernet Switch and USB HUB for aircraft...Comments (https://vansairforce.net/community/showthread.php?t=112051)
n468ac 04-17-2014 03:11 PM
Has anyone tried one of these ethernet switches in their plane?
http://www.alliedelec.com/search/pro...x?SKU=70229510
How about this for USB HUB?
http://www.alliedelec.com/search/pro...5#tab=overview
dynonsupport 04-17-2014 03:55 PM
We recommend this Ethernet one to our customers, from Steinair:
http://www.steinair.com/storedetail.cfm?productid=531
Snowflake 04-17-2014 06:37 PM
Originally Posted by n468ac (Post 872017)
$200! I'd try this first:
http://www.iogear.com/product/GUH274/
MJarreau 04-17-2014 06:57 PM
N-Tron Switches
We use them extensively at work and recommend them often to our customers. They are robust. Do you need what they can do for you? Disclosure: We have not used this particular switch, we use mostly the 500 and 700 series switches.
Good luck!
Michael
SteinAir 04-17-2014 07:15 PM
There are indeed a number of good options out there. We've tested a number of them, some much more expensive and some cheaper. The reason we have the one we have is the variable input voltage, and also it's semi-industrialized. We ended up stocking these due to very frequent and common failures customers routinely had/have with the really cheapo ones!
Like I said, there are a number of decent options out there, but we just did the homework already and found a decent one that works at a 'reasonable' price. For USB, we haven't decided to pick any specific one just yet...but maybe in the future.
Stein
dougweil 04-18-2014 09:00 AM
I initially installed a cheaper "consumer" ethernet hub for my AFS installation on my -7. It worked OK until the first time the airplane sat on the ramp on a 95 degree day and the internal temperatures exceeded the limits of the hub. It quit and I tossed it for the "semi-industrial" unit that Stein sells. No problem since!!
n468ac 04-18-2014 09:05 AM
Thanks everyone ... i'm going to be testing both of these at a customer in there factory. Its always between 90F and 130F, so it will be a good long term test.
