Tip: Plastic Floor Mat to Protect Plans
I was trying to find a material to use on my workbench that was clear so I could view a set of plans, and tough enough to withstand scrapes from metal edges.
After looking around, I went to Office Depot and picked up a hardwood floor computer chair mat. These don't have the normal spikes that you would find on a mat for carpet, so they are perfectly flat. It cost me $25 for a large mat which is big enough to hold two plan sheets stacked one above the other. You can even order a custom size, if you want a mat that will cover your whole table without that extra 'tab' that sticks out. Here's how mine looks: ![]() |
That's a really good idea!
Thanks for sharing.
John |
Also, Aircraft Components and Equipment (Ace Hardware) sells clear acrylic sheets the exact size of the plans, works great. If I remember, it cost me around $15. (Jeff Point strikes again).
Try your local hardware store
Here in California, my local hardware store (OSH, aka Orchard) has wide rolls of plastic. I had them cut off eight feet or so for a dollar-odd a foot.
| All times are GMT -6. The time now is 07:36 PM. |
