another place-- lines laid well right here. sure works great, glad I have it, although I don't use it all the time.
I like how you've installed your parking brake valve. Looks good! Have you tested it yet? Has anybody else put a valve in a side-by-side RV in a place where you can reach it without using a cable? Thank you, |
Fin 9A |
Jim
Good idea mounting the valve upside down (compared to my installation). Your slot is shorter as less movement of the lever is needed to activate the valve. Fin 9A |
data point
Picture with plans
I stole,errr ... I mean borrowed, Dave Parsons' idea. The existing rivet and bolt holes were used. I did have to double up on .040 behind the actual valve to allow countersinking in order to maintain a smooth firewall.
http://caura.dyndns.org/gallery/album01/ajy?full=1 Good luck, |
| All times are GMT -6. The time now is 11:54 PM. |
