VAF Forums
-   Fuel Injection Systems (https://vansairforce.net/community/forumdisplay.php?f=94)
-   -   Throttle body fuel injector (https://vansairforce.net/community/showthread.php?t=110235)
tec140 02-26-2014 01:42 PM
I have a throttle body fuel injector (Rotec Engineering) installed on an ECi O320
160hp engine. It will not idle below 900rpm without engine quitting unless I activate primer. Anyone with knowledge of TBIs that could help would be appreciated. Thanks
rhill 02-26-2014 02:02 PM
Rotec
Idle bypass mixture circuit may be clogged or slide closing stop may have moved? These need carb heat if I remember.
pitts flyer 02-27-2014 01:46 AM
I had essentially the same problem. Had to send it back to Rotec for repair--mine was a manufacturing defect. They fixed it under warranty (but you have to pay the shipping costs under their policy).
SHIPCHIEF 02-27-2014 02:14 PM
http://www.rotectbi.com/Installation.html
My son has one of these on his RV-4. It works great!
He did spend some time adjusting the idle mixture screw, which is behind the slide throttle actuator, so a low profile tool is a help.
Once set up, it has been a reliable and accurate fuel metering device that works with inverted flight.
