Radio intercom puzzle
I have to order the avionics kit in a few weeks for the new 12 I am building now.
Looking at the order forms there is a huge price difference between the US and European version and I cannot work out why. $ 1925 more !!! We need the 8.33 channel spacing in a year so we need the garmin GTR225. It seems to have a less quality integrated intercom so VANs sells this with a seperate PM3000 intercom. Now for the puzzle. The 200 sells at $1199 and the 225 at $ 1195 at Aircraft Spruce, so hardly dufferent. The PM3000 is offered at 420 and assume an additional harness fot $ 80 Where did the other $ 1425 go to ?? Anybody have a clue ? |
That one expensive sticker!
The GTR 225A is the version with the 8.33 khz spacing. It is $2585 at spruce. The price difference goes to pay for a really expensive sticker, the TSO tag :D
When I look up the GTR225 at Aircraft Spruce it says US$1793.00.
(The Gtr225A is $2585.00, as LNSelf said). http://www.aircraftspruce.com/catalo...rmingtr225.php http://www.aircraftspruce.com/catalo...ingtr225ab.php |
In your link you can also see the 200 in the right for 1199 which is the exoerimental version, which I suppose we need.
The non certified version of the 225 is $ 1750, which still adds up to a vanished 900 dollars.
Van's supplies the GTR 225A
Jack,
The RV-12 European avionics kit should come with the GTR 225A. There are three versions of the GTR 225 with several different price points: GTR 225, 225A, and 225B. The GTR 225, 225A, and 225B are all certified radios. The GTR 225 is a 10 Watt radio and has 25kHz spacing. The GTR 225A is a 10W radio with optional 8.33kHz spacing. The GTR 225B is a 16W radio with optional 8.33khz spacing. Van's RV-12 avionics order form just states "GTR 225", but it must be a GTR 225A to have the 8.33kHz spacing. A quick call to Van's would confirm that and would explain the price difference. This brochure from the Garmin website contains all of the GTR 225 information: http://www8.garmin.com/aviation/broc...R_225_spec.pdf Best of luck to you! -Levi |
Thats good information, but still does nit explain the big price difference.
The additonal cost for the 225a above the 200 and the PM3000 account for about $ 1200, so still missing some 700 bucks. I have put this question to VANs |
TSO
are you required to have TSO'd radios to operate in Europe? In the US, experimental aircraft don't require that certification. It makes a big difference in the price (though I suspect the radio itself is probably identical)
Gordon Turner |
Non TSO is accepted but Garmin has no other choice.
I have an 8.33 kHz ICOM 210 in my other RV12 which is fine but does not communicate to Skyview. Also the flightcom intercom is poor and always noisy |
| All times are GMT -6. The time now is 04:34 PM. |
