Vizion
Is the control wheel steering button normally open? Also the emergency wing level option? NO?:confused:
Yes
The CWS and Level switches are normally open.
The CWS switch is normally open. The AP level button is supplied by us, but is also normally open.
Did more testing yesterday with my Vizion, I don's see why you need to enter the attitude at start up? In flight without making any prior adjustment to set the altitude, It always matched the G3X. I went into the set altitude mode on the Vizion, and made a Baro adjustment on the G3X and watch the Vizion change as the G3X did.
Does this same functionality apply to Arinc429 data coming from a GRT EFIS? I'd really like to avoid a mis-match between EFIS and A/P altimeter settings and having that synchronization happen automagically would be the desired means of accomplishing this task.
I'm still work on a procedure that feels comfortable changing altitudes through the Vizion once the G3X altitude bug is present? |
GS ARM Question
Does the Vizion need to see a one-dot-up GS indication for several seconds in order to switch to GS ARM?
To arm, it needs a valid signal from the GPS, to be under the glide slope, and in altitude hold for at least seven seconds. VDI position doesn't really mattter, as long as the other conditions are met.
I had a Beta unit and flew with it for several hours... Then I went to Springdale and flew with Andrew and Zach at TT.... They incorporated essentially all my comments, and while the Beta unit performed flawlessly, I now have the new software and the user interface is excellent as well....
This autopilot is a tremendous bang for the buck!!!! With this AP, you can activate the Approach in your G-430, initiate a descent to the initial approach altitude, and it will descend, capture the initial altitude, fly to the FAF, switch to Approach mode, and take you to the fixed distance markers without touching ANYTHING!!! Truly an amazing upgrade to the Digiflight II series autopilots..... |
Sweet
Can't wait to go fly a coupled LPV approach with mine (when my new shoulder heals). Doug, did it switch to 'Approach mode' by itself?
Best, |
Sweet
Best, |
| All times are GMT -6. The time now is 08:58 AM. |
