VAF Forums
-   RV-7/7A (https://vansairforce.net/community/forumdisplay.php?f=7)
-   -   Cockpit head clearance (https://vansairforce.net/community/showthread.php?t=109118)
ADM 01-26-2014 02:30 AM
Hi all,
I'm looking at purchasing a 7 but haven't had a chance to sit in one to see if I fit in!
I'm 6"4', will I have enough leg and head room?
Cheers
Albert
MarkW 01-26-2014 05:44 AM
It all depends on how it is set up. I am 6'5" and fit fine. I built with the rudder pedals all the way forward and did not extend the panel down 2" as some builders do. I only have about 3" headroom but it works.
Bruce 01-26-2014 05:49 AM
Same as Mark.
I am 6'4 and no problem.
Use thin cushions also.
Rotorheadrob 01-26-2014 07:38 PM
Size Matters... if you don't want to go with a -14
If it's tight there are options to help.
Check out this site for a fix:
http://www.antisplataero.com/Almost_..._Seat_Mod.html
