RV-6 Electric Boost Pump Location
If anyone has pictures of their boost pump location I would appreciate some help. I purchased a flying airplane that has the pump located in the cockpit along the R passenger side just forward of the spar. It is awfully intrusive and an eye sore. I would sure like to relocate the pump.
Thanks, Dean |
That was the original location depicted in the plans... actually it was shown on the pilot side but the right side works better with where the engine drive fuel pump inlet is.
A lot of RV-6(A)'s have been built or updated with it located like the plans show for a carbed RV-7 or 9 (on the lower center firewall hidden behind a cover), but this also requires relocating the battery fwd of the firewall. |
Fuel pump location
My fuel pump, fuel switch and fuel filter all sit forward of the spar in the middle. You can see the components outside the plane at http://dmack.net/map_cockpit.htm
Installed - http://dmack.net/plumbing2.html It is very unobtrusive. |
| All times are GMT -6. The time now is 04:31 PM. |
