VAF Forums
-   -   Building Tip - Elevator Trim Hinge Pin (https://vansairforce.net/community/showthread.php?t=1078)
f1rocket 03-31-2005 05:49 AM
This is an idea that many people have used in the past. Unfortunately, I found out about it after I had built my RV-6. I struggled with finding a way to secure the hinge pin on the elevator trim tab until I saw this technique used on some RVs that I looked at up at Air Venture.
As supplied in the kit, the hinge is longer than what's needed. When you trim the hinge to length, be sure to NOT cut the hinge pin. Leave it long and extending past the end of the elevator as shown above. Now bend the hinge pin so that it will lay across the web of the spar.
Take a spare piece of hinge and cut out one eye. Drill a hole in it for a #6 screw. Slip it over the hinge pin and locate the position of the screw hole in the web of the spar. Remove everything and attach a #6 nut plate behind the hole. The nut plate will fit on the forward side of the elevator trim spar web where it extends past the edge of the inside elevator rib. When you're done, you'll find that you will be able to get a long bladed screwdriver on the screw even with the trim tab mounted and in-place.
Build9A 03-31-2005 07:01 AM
great tip
That's a great tip. It sure looks better than my safety job. I'm going to retrofit one on my elev. trim. thanks, Jack
fehdxl 03-31-2005 07:41 AM
I agree, excellent information! Too bad we can't search this site for the word 'tip' ... too few letters. Maybe we could use a keyword such ast BTIP for Building TIPs? Just a thought. Anyway, thanks for the information Randy!
-Jim
o=\o
Keywords: BTIP, tips, tricks, hints, safety,
f1rocket 03-31-2005 08:43 AM
Just FYI, I asked Doug a couple of months ago if he would set up a category for building tips. I could see where it would be hard to control what got posted there, but it might make it easier to find stuff.
Anyway, I have a couple more tips I'll post in the coming days.
H6 RV-6A 03-31-2005 11:42 AM
THANKS!! I was just finishing up my trimtab and was trying to figure out how to secure it.
Chris
alpinelakespilot2000 03-31-2005 12:48 PM
I'm just getting ready to attach my trim tab on my -9 now. Is there any reason not to just bend and safety wire the hinge pin like the blueprints suggest? Is this a "cosmetic" issue only or is there some structural/safety issue for screwing the hinge pin in place?
Regardless, thanks for providing the detailed tip--the pics really help.
Steve
Build9A 03-31-2005 01:23 PM
elev trim hinge pin
It's not a safety issue. The safety wire works fine. It's cosmetic only. Jack
n2prise 03-31-2005 09:26 PM
Thrifty and simple..
Van's guys have designed things to be simple and economical. Safety wire is cheap and effective for this application. The hinge tab is how Van's secures the two hinge pins that hold the upper and lower cowl together.
Jerry K. Thorne
East Ridge, TN
RV-9A N2PZ
RudiGreyling 03-31-2005 11:32 PM
Nice tip, and yes a "building tips" forum category would be great and easy to search.
Ron 04-05-2005 06:57 PM
Hinge Placement
Does each side of the hinge slide into the respective spars until the eyes meet the skin, or is there a set distance, Unless I'm missing something, I can't see on the plans..It looks like a 1/4" which is the thickness of the eyes..
