VAF Forums
-   RV-7/7A (https://vansairforce.net/community/forumdisplay.php?f=7)
-   -   G3X GSU 73 mount location and G23X (https://vansairforce.net/community/showthread.php?t=107716)
Flyyak 12-17-2013 03:31 PM
I have both GSU 73 and GSU 25. I note the different locations for GSU 25 on other thread. Any photos of GSU 73 and Any photos of G23X. I have a tip up. Thanks
neil clay
BillL 12-17-2013 04:07 PM
Here you go.
Note the 23 is located under the center rails. I did the calculations for deflection of these rails at 6 g and 2x weight. They calculate to move .001". Both are mounted with plate-nuts with screws coming from underside for service. The 23 is spaced down by 1/8" to make it easier to align for insertion.
I can provide all dimensions and more detailed photos if you desire.
War Eagle !!
