VAF Forums
-   Fuel Injection Systems (https://vansairforce.net/community/forumdisplay.php?f=94)
-   -   FI Servo Supply Hose (https://vansairforce.net/community/showthread.php?t=107679)
Capflyer 12-16-2013 12:59 PM
Looking for some help identifying which fuel hose Vans sells that connects the fuel spider through the lower baffle between 1&3, and then connects to the FI horiz mounted servo. It has -4 AN fittings on each end and is approximately 20" long and probably fire sleeved.
MarkW 12-16-2013 01:07 PM
Mike,
I don't believe Van's has much available for #4 hose assemblies.
You are a lot closer to Tom anyway and he will make the exact length you need.
TS Flightlines.
Toobuilder 12-16-2013 01:36 PM
There's no law that says it has to be a hose assembly. I made mine of stainless hard line.
flion 12-16-2013 04:41 PM
Vans doesn't sell it. It should have come with the engine or the FI kit or you will want to have one made up.
glenn654 12-16-2013 09:04 PM
Mike,
Do you have any pics showing the hardline?
I am looking at doing this but don't have any good places to secure with adels.
The nearest bolts are sump bolts and are vertical.....
Do you think it would be OK to put make an "S" turn so I'll have a horizontal section to secure with a clamp?
Glenn Wilkinson
Toobuilder 12-17-2013 07:01 AM
Originally Posted by glenn654 (Post 835265)
Mike,
Glenn Wilkinson
Pictures will take a bit of effort, but I might be able to describe my setup:
Forward facing servo with the fuel outlet pointing up toward case; straight AN fitting on the servo so line exits, makes a 90 toward the left wing following the oil pan rail, then another 90 to the tail still picking up the oil pan rail bolts, then another 90 "up" between the cylinders at the provided baffle cutout. I made a new baffle cover plate with a bracket and an adel here. Probably overkill but I wanted to make sure there was no baffle to line contact. As the line exits the top of the engine there are a few bends needed to attach the flow divider, and the pushrod tube happens to provide a convenient location for another adel.
Not sure what you mean by needing a bend to make a horizontal section- remember, a simple 90 degree bracket changes the orientation of the adel, so if you can't pick up case bolts, then a bracket almost always works. You definitely want a bend or two in the line simply to deal with expansion/contraction issues (general practice), but not so much that you create unsupported length. So yes, an "s" bend can work as long as it's not overdone. Clear as mud? ;)
BillL 12-17-2013 07:25 AM
What do you need?
CapFlyer/Mike
Size length, or just part number? I have the factory new IO360 M1B hanging on the hook now and will have to remove this hose and send for modification to fit the red cube.
I can get the dimensional information if that is what you need. I suspect it is a Lycoming part - is that number on the hose tag? Just let me know.
Capflyer 12-17-2013 03:15 PM
Thank you for the responses. I was hoping that it would be a simple ID of a pre-made hose that Vans sells but apparently not. I'm leary of using a hard line in this area because of vibration and being next to the hottest parts of the engine on its run between the cylinders. I think I'll just have one made locally at a place that speciallizes in hydraulic hoses plus they can pressure test it.
Toobuilder 12-17-2013 03:32 PM
Whatever you decide to do is up to you, but don't cite better heat resistance as a "plus" for hose. You're not going to do better than stainless hard line in that department. As for vibration, well, "standard aviation practices" are there for a reason. Follow them, and you'll have no issues.
glenn654 12-17-2013 03:52 PM
Michael,
Yeah, I think I have a good idea of what you mean.
Your description was helpful.
Glenn
