B&C Starter Horizontal injection
Has anybody installed a B&C starter with the horizontal injection? I'm trying to figure out if there is a clearance issue with the servo and/or the fiberglass intake snorkel.
B&C starter
I had to make a number of mods to my snorkel to accommodate the B&C starter on my -8. It seemed to work out. Let me know if you'd like pics.
Bill,
I would appreciate pictures very much. How much clearance do you have with the mixture cut off? |
B&C starter
Hi Tim: I had to reverse the control lever for the mixture, pointing it down and fabricating a new cable bracket. I'll try to send a pic that shows some of this. Can you give me your e-mail? Bill
I'll send you my email as well since I'm also having clearance issues with my mixture lever. Silverhawk FI/B&C Starter.
I'll send you my email as well. I can also post the photos if you like. Thanks! Russ |
Bill, you're over your private message quota and it won't let me send you my email. But you can decode it here:
[my first name] @ [my VAF username].com Also, please tell me if it's OK to post the photos to this thread. Thanks, Russ |
Bill,
I sent you a PM, not sure if you still have those pictures of your snorkel mods. I am going to do them too. Russ, perhaps you have Bills pictures still, or perhaps some of your own? :confused: CJ |
B&C Starter, IO-360, Bendix throttle body, horizontal induction and snorkel
I replaced my SkyTec Lightweight starter (literally broke) with a B&C starter on my RV-8 equipped with IO-360, Bendix throttle body, horizontal induction and snorkel.
Don at Airflow Performance was a big help. I bought his 1.5 inch offset throttle lever to replace my mixture lever. It clears the starter and my mixture has full travel using the Airflow Performance lever. I had to do a bunch of surgery on my snorkel so it would clear the starter. Turned out pretty good for my first exposure to fiberglass. First start with B&C starter was today. Very impressed by how fast the B&C starter spins the prop compared to the Skytec. The B&C doesn't draw as many amps initially as the Skytec. Permanent magnet (SkyTec) vs wire wound (B&C) with a gear. The B&C worked on the first try. The SkyTec used to require two sometimes three bumps to get it going. The B&C starter is a work of art. Glad I made this decision. I used to cringe every time I tried to start my engine with the Skytec starter. The B&C makes me smile. I gained 2 pounds up front going to the B&C. It cost more but I'm worth it. |
| All times are GMT -6. The time now is 04:57 PM. |
