VAF Forums
-   RV-6/6A (https://vansairforce.net/community/forumdisplay.php?f=8)
-   -   Has anybody Sikaflex'd a RV-6 Slider? (https://vansairforce.net/community/showthread.php?t=107038)
Pittsartist 11-26-2013 03:38 AM
I'm beginning to consider how to tackle my canopy fit and I quite like the idea of using Sikaflex as opposed to riveting.
I've done a bit of a search on old threads and I can find loads of stuff for other models - but nothing on the "Slider" '6
Has this been done before ?. Good Idea ? (or not ?) can anyone point me at more info for the '6 ?.
RV7AJeremy 11-26-2013 04:12 AM
I glued my 7 slider. I can't see how they would be significantly different. I would glue again too, no drilling for me.
WingsOnWheels 11-26-2013 05:06 AM
I plan to glue mine also. The canopy parts are the same as the -7, so there is no reason you can't do it on the -6.
ChiefPilot 11-26-2013 06:02 AM
I did it on -6A slider, and I'm extremely pleased with it. The only hole I drilled was for the canopy latch - everything else got Sika'd. I even Sika'd the composite rear skirts to the canopy. Very happy with how it all turned out.
Virtual Hanger post
Scott_F 11-26-2013 06:46 AM
For those of you that removed the powdercoating before glueing, how did you get the powdercoat off? I would like to leave it on the lower side rails where the fairings attach, but remove it from the bows where the plexi is attached.
turbosaaber 11-26-2013 09:54 AM
coarse sand paper
I just used coarse sand paper to rough it up then applied sika. So far so good....
RV7AJeremy 11-26-2013 10:37 AM
I just roughed it up also for the sika, but I did remove a lot of the powder from other parts. I found the best method for me was to rough up the powder coat, then apply a chemical paint stripper, then use a wire brush on a bench grinder or angle grinder. Worked better than blasting for me.
ChiefPilot 11-26-2013 07:45 PM
I used a chemical stripper + wire brush to take all the powder coating off the canopy bow and roll bar, then primed & painted it flat black. I left a strip of bare metal for the sika metal primer.
rstisser 12-01-2013 08:26 PM
Food For thought
A few days ago I had a nasty surprise when a 20inch crack suddenly appeared right over my head in my slider after a cold weather flight. I am going to try to repair the crack with adhesive, but if that fix fails a replacement canopy will need to be fabricated. How does one remove the plexi when glued onto the frame?
whittfic 12-02-2013 08:26 PM
Heat gun and thin scraper. It's a two person job, hold the frame down reasonably firmly and don't be in too much of a hurry. Probably easier if you break away the bulk of the acrylic before starting with the heat.
Clive Whittfield
Auckland
New Zealand
