VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   2 pc vs 4 PC nose bearing (https://vansairforce.net/community/showthread.php?t=106705)
Sid Lambert 11-17-2013 04:13 PM
I'm trying to find some documentation on when to convert from the 4 PC nose bearing to the 2 PC.
Does anyone know a lycoming document that spells it out or can tell me when to change?
LifeofReiley 11-17-2013 07:46 PM
Don't have a document for you but I always will change the 4 piece to a 2 piece big bearing. Divco advises when taking a 320 from 150 to 160 hp, might give them a quick call in the morning and see if they can lead you to a document. Oklahoma time. :)
rv4ross 11-18-2013 05:52 AM
If you do find out it's possible to do, could you post it? I just got my case halves back from Divco and if no machining is required, I'd be interested.
Ross Scroggs
RV4 Finishing Kit #3911
Locust Grove, GA
Dues Paid 2013
az_gila 11-18-2013 07:09 AM
Ross Scroggs
Locust Grove, GA
Dues Paid 2013
I'm sure it needs machining. ECI charges $137 and calls it a modification...
http://eci.aero/pages/repairs_cca.aspx#Modifications
LifeofReiley 11-18-2013 07:20 AM
Gil is correct, it will take machining. IMHO, worth every penny. :)
