Mounting WAAS antenna on glare shield
I'm installing a Garmin 400w and want to mount the antenna on the glare shield. Is is OK to mount it crossways (turned 90 degrees)? My glare shield is too narrow to mount the unit in the normal orientation.
John |
If the antenna is inside the aircraft, then as long as it is mounted on a (nearly) horizontal surface with a good view of the sky, it should work just fine in any rotated orientation on that horizontal surface.
Hello John,
GPS antennas are not directional, aside from aerodynamic considerations which don't apply when mounting the antenna inside the aircraft. As long as the antenna is situated where it has a good view of the sky in all directions you should be just fine. A further thing to consider when mounting a TSO WAAS GPS antenna on the glareshield is to take into account the minimum cable length requirement from the installation manual: Quote:
- Matt |
I have a couple antenna mounted on my glare sheld and don't like them there.
Reflections from them are on the window at times and is a bit distracting. Recommend putting them behind you if able or under the engine cowling. Good luck, RC |
Have you considered mounting it under the cowl
John |
Thanks all. Lots to think about. My antenna cable is about 4'. Didn't realize that it could be too short. I hadn't considered the reflection of the antenna on the canopy either.
John |
I was thinking of covering it with electrical tape.
| All times are GMT -6. The time now is 11:31 AM. |
