for some reason people seem to fall into the hole of improper seat back placement. i have noticed on a couple of sites builders assuming it is normal for the seats and canopy roll bar to interfere.because others have said "there all like that, the plans are incorrect" the cause is measuring from the wrong reference point.you are suppose to measure from the edge of the seat pan and not from the centerline of the screw holes. the screw hole centerline is for hinge pin length. the design is correct. no need to be ill with vans the print is very busy. stay sharp.
Radomir
09-01-2006 11:20 PM
Good catch. It'd take about 30 seconds for Vans to update this drawing with a note.. It's unclear why they haven't done so already.
