Traffic with ADS-B in
Just wondering, with only ADS-B in (dual frequency), would I see only the traffic that has ADS-B out or all traffic that is in the system (those also with only transponders)
Thanks in advance |
Complicated
You'll pick up direct signals from other aircraft broadcasting with a mode S. The ground stations will not send you traffic (uplink) since they do not know you're there, since you have no ADSB-out. But if there's a nearby aircraft with ADSB-out then you'll piggy back on the uplink intended for him, and get traffic.
| All times are GMT -6. The time now is 10:16 PM. |
