VAF Forums
-   RV-8/8A (https://vansairforce.net/community/forumdisplay.php?f=6)
-   -   Question About Aileron Pinching (https://vansairforce.net/community/showthread.php?t=105214)
SuperDave 10-14-2013 08:50 AM
Originally Posted by cfiidon (Post 816244)
That sounds significant to me. My original imbalance was about 7 gallons of fuel. After l pinched a bit, I discovered that the trailing edge of my flap was 1/4 inch low. Corrected that and all is well.
I might suggest you check all alignment and get it as close as you can before any further pinching happens. Is your aileron trim disconnected?
Don
You're right, that is significant. I've thought of adding a child's seat out on the left wing for my 10 year old daughter but she is just going to keep growing so that wouldn't be a permanent fix.
The aileron trim is connected and it is servo-operated. With equal fuel in both tanks and the trim all the way to the left the plane flies pretty level.
