Slipping an RV-6A on final
Hi all! I've noticed how nicely my RV-6A loses altitude in a slip on final. But I only use about 1/2 rudder / aileron since I'm not sure about using full cross controls. Any slipping advice out there for an RV-6A?
Just go to altitude and practice. Keep the speed up and and don't slip up. I usually do my slipping during the turn. By the time I roll out I am 90% there. Abeam the numbers, full flaps, slip in the turn, hit the spot. Good practice. :) I usually don't need full controls.
RVs slip great with full controls. Normally full control is not necessary, but it works fine.
I do it often as I often land clean or with 1/2 flaps. Bleeds speed and altitude nicely. The -6 slips awesomely. :)
Slip
Good technique to have in the bag of tricks for precautionary landings. As mentioned above do some fam at altitude, as you get comfortable, combine in normal pattern work. Plane slips great, effectiveness is certainly there. Perhaps others do it better and some worse.
Part of it is technique. If you've got full flaps, a full slip, and still aren't coming down fast enough, it seems odd to blame the aircraft.
Just sayin'.... |
While my -6 doesn't slip as dramatically as my old Cherokee 140 would (that plane was a piece of cake to do "slam dunk" approaches in), the -6 does indeed slip just fine. I rarely find the need to slip it however, since if you just slow down to about 75 MPH on final, then it'll drop like a rock plenty quick enough :D
| All times are GMT -6. The time now is 12:14 PM. |
