for a comparison a viking with fwf is about $18g and a gps, grt eis and steam gauges can probably be had for $4g or less. that takes $18g off vans sticker of $64g.
not saying viking is the answer but choices is what homebuilding is all about. |
I have done enough research to suggest that Viking engine is an excellent choice if one decides to go EAB. I am going that route in my build.
What happens to the resale value/ability when you do EAB
When you go to sell an ELSA RV-12 you have a fully engineered and documented build. The new owner can do his own annual inspection just by attending a 16 hour course. These two items add resale value and probably will expedite resale on the market to a new owner.
To the OP welcome to the dark side! ;). :D
How about a partner to split the costs? It is a great project for 2 guys to work on togeasther and build it ELSA. Then you don't have to worry about what you designed and built, Van's did it for you. Just a thought. ;) It is a great plane to fly and maintain. |
If frugal is what you want, build an RV4...
Richard Bibb |
Firewall Forward UL Power
| All times are GMT -6. The time now is 11:58 PM. |
