VAF Forums
-   RV-12/RV-12iS (https://vansairforce.net/community/forumdisplay.php?f=73)
-   -   Do the plans specify which parts need to be primed? (https://vansairforce.net/community/showthread.php?t=104567)
uuacallis 09-21-2013 07:39 PM
So I am not trying to open up another primer war, so lets just assume you choose NOT to prime anything except what is required (steel etc), do the plans tell you which parts need to be primed?
Before someone comes back with the standard answer of "Anything that isn't Alclad needs to be primed", I know that, what I am asking is if there is anything that identifies a specific part as requiring priming other then me knowing that the specific part isn't Alclad.
thanks
txaviator 09-21-2013 08:32 PM
Adam,
Short answer is yes. At least on the older plans, where you had to fabricate a lot of your own parts. The plans would tell you to prime. But now it's my understanding that some of these brackets are factory built, so I'm not sure about the latest kits. But my plans (within the past 2-yrs) did tell me specific stuff to prime.
uuacallis 09-21-2013 10:51 PM
Do you have an example page# where it calls out the priming in your plans?
DaveLS 09-22-2013 07:07 AM
Here is an example:
Page 23-06 Step 4: Remove, debur and prime the Longerons F-1255-L &-R.
-Dave
uuacallis 09-22-2013 07:28 AM
Unfortunately I only have the empennage kit, so my plans don't go that far yet.
rgmwa 09-22-2013 07:33 AM
As Gary said, apart from the generic instructions, there are a few places in the plans where you are specifically required to prime parts.
DaveLS 09-22-2013 07:42 AM
Adam,
Many pages of plans can be downloaded from here:
http://www.vansaircraft.com/public/12_Rev_page2.htm
And here:
http://www.eaglesnestprojects.org/Pr...Resources.aspx
What's your serial number, wondering how many RV-12 have been started.
-Dave
bhassel 09-22-2013 07:46 AM
Originally Posted by DaveLS (Post 809578)
Here is an example:
-Dave
I suspect the plans have changed a little since page 23-06 is about installing the side skins. While I haven't started the fuse yet, I do have the kit and plans. I didn't see anything there about primer.
Good question though, I've wondered myself.
Bob
uuacallis 09-22-2013 07:53 AM
Thanks all for the help, I am just really confused. Looking through the parts that came as part of the empennage kit, I am not seeing anything that needs to be primed, yet I am sure there are many pieces that do. I guess I need a better way of knowing that something needs to be primed.
As for the serial number, I am 120783
Gagarin737 09-22-2013 08:06 AM
Look in the general instructions 1-5:
"5A ALUMINUM & PRIMING & PAINTING
All non-alclad aluminum parts such as 6061-T6 must be primed. Tubing must be primed both inside and out"
For example the tail skid F-1211G is 6061 and needs to be primed.
