Contact Adhesive Removal
I have been fitting the headliner and got a little enthusiastic with the spray glue and it has seeped through the fabric in a couple of places.
What's the best way to remove contact adhesive without destroying the fabric or taking the colour out? |
That will be a tough one, Paul. Maybe start with some mineral spirits or naphtha. Here in the States, we have a couple of products, Goo-gone & Goof-off, that may work. I would certainly do a test before using anything.
This stuff from Spruce works well. I've only used it on hard surfaces but the description says it works on fabrics.
https://www.aircraftspruce.com/pages...adhesremov.php It's citrus based and doesn't smell nasty...:) ![]() A good car supply place/coachbuilders (US = upholstery shop) might also stock it. |
Thanks guys.
I've found a grease/paint/glue stain remover (naphtha based). I'll try that on some scrap and see how it goes. |
obviously something to try with care - but the advantage is no solvents / residues or abrasion marks. |
Not sure on the hair waxing but MEK will do the job.
Tough one. Try a quick dry electronic cleaner aerosol. Spray through the front to attempt blowing the glue back. What kind of fabric?
| All times are GMT -6. The time now is 04:02 AM. |
