| vic syracuse |
09-18-2013 06:45 PM |
Atlanta ADSB and Navworx ADS600-b
Is anyone in the Atlanta area seeing any anomalies with ADSB traffic in the last week or so? In the last few weeks on my daily commute in the Atlanta area I am seeing traffic fade in and out from ADSB, and it swaps over to TIS mode on the AFS 4500. Then sometimes it comes back to ADSB. On some days I will show 32 targets, and as I go by Atlanta Hartsfield I can even see some of the flight numbers parked at the gates on the ground. Other days I see 3-4 targets, or it reads ADSB 0 and then flips over to TIS. I've also noticed that my own target is boxed yellow intermittently and sometimes shows my N number and other times it doesn't. Sometimes a number of targets are showing on the ADSB readout and then they become yellow outlines boxes (coast targets I assume) and then it flips to TIS. Then sometimes it flips back to ADSB.
Navworx wants the unit back, but I'd rather not cause them work if the station is flaky. Weather appears to be fine.
Thanks.
Vic
