Dynon SkyView owners: thumb drive port ?
Cut holes in panel for my two Skyviews. Main 10" and pass 7" . I understand updating the skyview with a thumb drive is needed. I wanted to put a connection point on the instrument panel for this drive. ( I see Garmin already did this with their new EFISs.) What have you done to accomplish this? Will I need two Locations or just one? Pics helpful too!
Thanks Ron in oregon RV9A N421HJ |
Ron,
They include one with the RV-12. It mounts flush to the bottom shelf of the panel (facing down toward the floor). Maybe you can order one from Van's and integrate it the same on your RV9? The plans don't have a number for it. It's simply called "USB". |
Stein included USB ports for both my Skyviews. He has them in his catalog:
USB Extension Cable Product ID: USBCABLE3 Allows you to "panel mount" the USB access port for avionics or EFIS's such as the GRT / Grand Rapids Avionics EFIS Screens. These cables are 3' (36") in length. You simply cut a small hole in your panel and insert/mount the cable from the rear. NO more reaching behind the panel for software updates! |
On the -12, Van's provides a USB port as part of the wiring harness. It's fixed to the instrument panel shelf, and is out of sight and not all that accessible. Some builders have put a second USB port on the panel using a pigtail from one of the two ports on the back of the Skyview screen. Mine is just above the screen on the right as per the pic. Others have put it to the left of the screen. One builder installed his in the map box.
You need one for each display. Just asked this question the other day on the Dynon support forum:
http://dynonavionics.com/cgi-bin/yab...m=1379029880/3 |
icom
I used two mounted above my radio rack, I will post a pic. They work great. It is a separate unit with two cables, all lcom.
Take care, [IMG]/Users/carlbridges/Pictures/iPhoto Library/Originals/2012/Dec 20, 2012/IMG_0993.JPG[/IMG] |
Tip-up or slider?
I have a tip-up and rather than cutting the hole for the USB, I simply open the canopy and reach in and plug in the drive.
My SkyView came with the USB extension. Check with Dynon, you may have one in the box. |
The DYNON Skyview displays have two USB ports in the back of each display. However, getting to them to update the display can be a hassle. I connected a 12" USB port extension cable from one of the available USB ports on each display to a panel cut out just to the lower left of each display as seen in the picture.
Some people just connect the extension cable to the display and tie wrap them somewhere under the panel where it is easy to get to. Just do whatever is best for your airplane. :cool: |
Much appreciated guys! Ron in Oregon |
| All times are GMT -6. The time now is 01:13 AM. |
