VAF Forums
-   -   Oil Changes (https://vansairforce.net/community/showthread.php?t=103832)
Ironflight 09-02-2013 09:02 AM
Oil and Filter at 50 - as recommended by the manufacturer. With three airplanes and traveling as much as we do, I'd be an oil (disposal) company stock holder if I did it more frequently....
az_gila 09-02-2013 09:59 AM
Calendar time between changes
Paul forgets the other Lycoming oil change requirement because he flys so much....:)
The Lycoming service bulletin also has a 4 month oil change requirement if you don't reach the 50 hrs.
http://www.lycoming.com/Portals/0/te...Inspection.pdf
Also recommended by Mike Busch -
http://blog.savvymx.com/2010/03/changing-oil.html
panhandler1956 09-02-2013 10:18 AM
I'm a 25 hour guy too
I usually do both the oil and filter at 25 plus cam guard. I don't fly as often as I'd like, so it ends up being twice a year.
RV-4 09-02-2013 11:24 AM
Oil Change
Hello Gents
Thanks a lot for the replies.
The 25 hrs / o?l change and the 50 hrs / o?l & filter change are what I had in mind.
I had a screen only filtering system on my 0-320 E2D and I used to do the o?l changes every 25 hrs but I recently installed a filter adapter and was curious to know what o?l change schedule most of you used.
I also used a can of Avblend with every o?l change.
Also, what are you Guys doing once you've dump the o?l and need to replace the filter? Do you punch a hole in it so it drains better or do you just wait for it to drain completly.
With the location of the filter on a -4, any advise to prevent a mess is welcome..
Thanks again for the info
Cheers
Bruno
rv4@videotron.ca
turbo 09-02-2013 12:06 PM
Keep in mind, 30hrs Hobbs is really 25. I do 30/35 hr changes with filter every other time. Oil is cheap. MMO added also. Each to there own.
Mel 09-02-2013 12:22 PM
Obviously I have a different take on oil/filter changes then many here, but I will never change oil and run it through a dirty filter.
I will always change the filter any time I change the oil.
John RV8 09-02-2013 01:34 PM
I'm with Mel on this one. I would never change the oil without changing the filter. I also drain the oil cooler at each oil change to get rid of as much dirty oil as possible. I use the 50 hour interval for my RV-8
Not aircraft engines but as another data point I know most long haul diesel trucks change their filter between oil changes....
erikpmort 09-02-2013 03:22 PM
How much are the filters ? Is it really a big deal to just change it.
BobTurner 09-02-2013 04:06 PM
Originally Posted by RV-4 (Post 803632)
Hello Gents
Bruno
rv4@videotron.ca
You let it drain in a bucket, then you use your oil filter cutting tool to take it apart and examine it for debris.
BobTurner 09-02-2013 04:11 PM
Around $20. No it is not a big deal, but it is easy to make a mess, or to stab yourself with the safety wire!
