In Search of Small Kneeboard
Since my panel is full EFIS with approach plates, I no longer need to fly with my iPad Mini powered on and strapped to my leg for IFR charts. But, I do need to write clearances and frequencies down as needed. So I am looking for a small form factor kneeboard that's just big enough to hold a small pad of paper and will fit in the RV. Most of the paper kneeboards are multi-fold or overkill for what I need.
Has anyone found a good, small, lightweight kneeboard for paper? |
Try this one
Probably the smallest and most compact is the 9G. Popular amongst military. 9G Plus is same but with added strap. I have both.
http://www.mypilotstore.com/MyPilotS...FeRj7AodGjkAgw http://www.aircraftspruce.com/catalo...es/9g_plus.php Prices seem to vary between $35 and $45. |
I have a very nice simple kneeboard - it hold a standard 5x7 pad and has a couple of places to put pens/pencils. It's cordora type fabric and works great in the RV. Only problem is I don't remember the brand name off-hand. I'll check when I'm at my hanger.
Post #3 wasn't there when I was typing my reply - but that's the one that I have. |
Piccolo
Mark,
Don't know if they are available in the US but the Piccolo kneeboards are very good. Just 4.3" wide by 7.3" high. I have one and like it a lot. I print my own blank plogs from an excel template of my own design. I get 6 blanks (3 across by 2 rows) per A4 page. Print double-sided so get 12 flight plogs per sheet of A4 paper. ![]() Not that common here in Europe but found this German website that sells them. Dirt cheap. http://skyfox.de/Pilot-Supplies/Knee...ard-PILOT.html Steve |
You're a builder, right?
Make your own. I bought an inexpensive plain vanilla aluminum clipboard at Whatever Office Supply, cut it down to 7.125 x 4.125, then pop riveted on a wide velcro strap. Used it for many XC sailplane flights, placed in service in 1981. The photo was taken a few minutes ago. Never got around to removing the "slasher" pencil holder. Never got slashed enough I guess.
The hangar
Outside the gate of FT Rucker is a place called The Hangar.
http://thehangar.com/catalog/index.php A lot of Army pilots have shopped there and they have small kneeboards. Not a lot of room in some helicopters. Check out the W4 model. |
Minor downside... It doesn't hold a flashlight tightly. It will fall out moving it around (fine in flight when strapped to your thigh, just a problem moving in and out of the cockpit). |
| All times are GMT -6. The time now is 12:11 PM. |
