Excellent job handling your door off emergency!
Looking at your pictures it appears that you have a clean break from the rear.
I believe your rear pin was not engaged into any part of the fuselage.
Had your door separated from the top due to a fiberglass failure you would at least show some damage to the pin area front and back. The door would have been flopping around with the pins still engaged and finally come loose after enough flexing outside of the door frame.
I see no damage in those areas and having the rear pin not engaged allows the door to come off without tearing up the bottom end.
I am firmly in the camp of non believers of multiple safety mechanisms.
I have Van's stock door lock, (no center latch), aluminum guides and safety lights as per Vans instructions.
One of the leading causes of engine failures is still fuel starvation despite all the bells and whistles honking at us.
I am not accusing you of anything but the PIC must ensure that both doors are closed and locked.
I do exactly the same
I deliberately installed the lights front and center outside of the EFIS clutter
to make sure they stand out
I did install a handle on the rear bottom of the door to assist in ensuring positive engagement of the rear pin.
