I also push against each door's front and rear as a double-check before departure. Best, |
David, if you have a build/pilot partner and when you are the passenger he is the pilot. He closes all doors and you trust him to close all doors, why not trust him to close his passenger door when you are the pilot. If you say liability, he assumes half the liability whether or not he is flying. Other than third party liability, ie. the door falls on someone.
I actually used micro switches at the end of the pins. I found the magnets were not accurate enough to assure that the pin was always fully engaged. In our installation, the pin must touch the micro switch to close the connection. All the switches are in series and report to a red annunciator light on the panel, and also an analog input on the EFIS. The only thing I would do differently would be to separate the left and right door annunciation.
I am also thinking that the doors halves may have not had good adhesion, which allowed a lot of flex. My pre-flight always includes inspection of the door latch and pins and their operation with the door in the open position. My checklist includes two separate entries to check the door latches. I always touch all four points of engagement and check the latch. I never let the passenger latch the door. |
Handle on aft end of door
I added a handle to the aft end of the door, so when ya close it you can pull it in tight against the frame fwd and aft when you are locking it. It's a two hand operation, but it makes for a very positive closure.
RV10 Door
I will have Troy call Gerald this morning. We can help.
We replaced a lost door on a RV10 last year. We had Vans send us parts and we took them to the plane. We installed the door in the usual manner. With the door attached but NOT operational, we ferried it over to RV Central. Then we finished it up and made it paintable. While it was here. We installed some after market door handels, installed an aircontitioner and the Safety magnets in the door latch holes. The door was lost on that one. We might be able to repair Gerald's door since he still has it. |
On my door (180 kit) there is no possible way for one pin to be engaged without the other and no way the door will come off unless it is not closed and latched. You state both pins were fully engaged so it leads me to believe the delamination of the door skins caused the door to fold in the middle and pull the pins out. On a 180 door kit you should have about 1-1/2 of pin extension in each guide. The cam only needs 30 degrees of rotation to fully engage so less than 1/2" of retraction in the door. 180 degrees equals around 2 inches of lateral pin movement. 1-1/2 inches of distance is a lot on each pin side to pull out of the guides. I wish I could see this door before and after. |
That was my initial thought as well. That maybe the door skin itself was defective. The epoxy of the inner skin with outer skin may have failed somehow. We won't know until someone knowledgeable can examine the door and give a thorough analysis.
Order a new door from Van.
You can do it. In fact, you will be the perfect person for building a perfect door. Don't make a claim, and don't bother the sky cops (unless you declared an emergency). It's all part of life.... |
photo of door
Here is 2 photos I took of door, pins were fully extended when picked up door on runway so still think back pin not secured. Hope these links work, first time to play with photobucket.
http://i1360.photobucket.com/albums/...psb57cc197.jpg http://i1360.photobucket.com/albums/...ps9294f691.jpg Thanks Gerald |
| All times are GMT -6. The time now is 08:01 AM. |
