VAF Forums
-   RV-9/9A (https://vansairforce.net/community/forumdisplay.php?f=5)
-   -   Garmin pitot and safe air connection (https://vansairforce.net/community/showthread.php?t=103771)
o2flymy6 08-30-2013 05:41 PM
I am hoping for some ideas on the best methord to connect my Safe Air tubing (1/4" OD plastic brake tubing) to my new Garmin heated pitot lines (unsure of the OD). I want to obviously assure a tight seal on the system and need help your input with making this connection.
Thanks in advance for your input!
g3xpert 08-30-2013 08:52 PM
Hello Jim,
I saw this image on the SafeAir site that looks like it would work to connect your 1/4" tubing to the 3/16" aluminum tubes coming out of the GAP 26 pitot/AOA probe.
You would just need to flare the ends of the GAP 26 tubes.
I ran 3/16" nylon lines all the way from the GAP 26 to the GSU 25 in my plane and this allowed me to use a simple 3/16" to 3/16" push-to-connect coupling at the probe connection and no flaring, but I like the flared installation as well.
Steve
o2flymy6 08-30-2013 09:31 PM
I love this site!!
Whenever I get stuck on an issue or need insight the folks on that hangout here help. It doesn't get any better than this for me and I know I shall have a better build thanks to the resources here - thanks Doug et al..
380mxc 08-31-2013 10:28 AM
pitot
I see colored tubing in the above post is there a recommended color code system to be used?
Randle 08-31-2013 09:10 PM
If the tubing that is currently in my wings is 1/4" OD, will I have any issues with the volume change using a 3/16 OD pitot line? Is the regulated GAP26 available yet?
g3xpert 08-31-2013 09:37 PM
Hello Tim,
I don't think the color choice is important, but having different colors sure makes it easier to not make a mistake when you plug the pitot and AOA lines coming from the probe into the GSU 25 ADAHRS.
Steve
g3xpert 08-31-2013 09:53 PM
Hello Randle,
Since there is no flow in these tubes, there is no problem with transitioning from 3/16" to 1/4" tubing.
If the heated/regulated probe is not shipping yet, it is very close. We are wrapping up a new revision to the G3X Installation Manual (Rev. L) that provides more installation information for this probe.
Steve
flion 09-01-2013 06:35 AM
The SafeAir kit shows green for static, blue for AOA, and the remaining color (white in my kit, black in their diagram) for pitot.
kcpilot81 10-09-2013 04:10 PM
Steve, do you have any further insight into when Rev. L of the Install Manual will be published? Thanks.
g3xpert 10-09-2013 05:41 PM
Hello Keith,
Release of the Rev. L installation manual has been held up pending confirmation of some wiring diagram changes in support of a new engine sensor, but if you need an advance copy of the updated GAP 26 installation section, please send us an email and we will fix you up.
Steve
