VAF Forums
-   Fuel Injection Systems (https://vansairforce.net/community/forumdisplay.php?f=94)
-   -   Serrated throttle lever (https://vansairforce.net/community/showthread.php?t=103445)
Vansrv7arob 08-23-2013 05:47 AM
SERRATED THROTTLE LEVER of various lengths? I need one for a matti tuck io360?? The one I have doesn't give me the clearance I need.
centre to centre needs to be at least 2 1/4
inches.
11/16 dia serration - 24 serrations
3/32 wide
3/8 shaft
rzbill 08-23-2013 08:32 AM
I saw a list of RSA levers with part number assignments somewhere but I can't find it now.
I imagine Don Rivera can help you.
Airflow Performance contact page
**Edit ** Ah! found it!. Precision Home Page
Go here, click on SilverHawk Support, then Default Levers. I don't see a 2-1/4"
Vansrv7arob 08-24-2013 12:32 AM
Yeah 2" is the longest, I presume someone else has had this issue before, is there any alternatives like from car/ boat racing that might fit?
Doug 08-24-2013 03:31 AM
I think they are available from Precision Airmotive. Googling Silverhawk lead here, the default levers link leads to a range of part numbers.
http://www.precisionairmotive.com/silver_hawk_ex.htm
They to are limited to 2". I do recall seeing a photo of one extended with a section welded into to arm.
Vansrv7arob 08-26-2013 08:07 AM
Thanks everyone, looks like I'm going down the custom route, fingers crossed found someone who can mill the serrations with a special jig.
