https://www.pegasusautoracing.com/pr...s.asp?RecID=87 |
http://www.skybrary.aero/index.php/Ignition_of_Fuels |
fuel cell foam?
the Pegasus auto racing site also shows a yellow fuel cell foam that can be cut to any size and fit to fuel tanks.....albeit during construction for our tanks.
As I understand it dampens shock wave formation that causes tanks to explode, and slows leakage, and reduces combustible air/fuel vapour mixtures inside the tank. $54 for an 8x8x8" cube, E85 resistant. |
Aim for water?
Uh-oh, here we go again.... |
I have witnessed a decathalon that nosed over on landing with full tanks. The fuel simply leaked from the caps and vents and made a nice stream entering the cowl. There was no fire. Shutting off fuel would have had no effect in this situation. I know it is a high wing, but I think a similar outflow of fuel could happen in an RV sitting on its nose. Depending on how high the tail is, the fuel might reach a hot exhaust part. Just speculating, maybe somebody has seen an RV on its nose and can comment.
auto ignition temp of avgas 824?F / 440?C
ConocoPhillips
001769 - Aviation Gasoline, 100 LL Date of Issue: 23-May-2007 Vapor Pressure: 5.5-7.0 psia (Reid VP) @ 100?F Vapor Density (air=1): >1 Boiling Point/Range: 75-338?F / 24-170?C Melting/Freezing Point: <-72?F / <-58?C Partition Coefficient (n-octanol/water) (Kow): No data Specific Gravity: 0.68-0.74 @ 60?F (15.6?C) Bulk Density: 5.83 lbs/gal Percent Volatile: 100% Evaporation Rate (nBuAc=1): >1 Flash Point: <-35?F / <-37?C Test Method: (estimate) LEL (vol % in air): 1.5 UEL (vol % in air): 7.6 Autoignition Temperature: 824?F / 440?C Stability: Stable under normal ambient and anticipated storage and handling conditions of temperature and pressure. Extremely flammable liquid and vapor. Vapor can cause flash fire. |
These inertia switches were used on all Ford vehicles with EFI throughout the 90's up to at least mid 2000's: http://www.sensata.com/download/resettable-crash.pdf I even installed one in my injected '66 GTO. Install it near your main solenoid/contactor in series with your existing main bus switch wiring.
Heinrich |
Remember me I landed in the soccer field ? I hit that park sign going 60+mph and it sliced right into the fuel tank. Still waiting for the fuel tank to be repaired btw. But I was happy that no fire occurred. I did not get the fuel off before the landing admittedly.
| All times are GMT -6. The time now is 09:59 PM. |
