Which New Jersey Airport
I'm flying my RV-10 up to NJ to visit my daughter & family in early September. I've found four small airports that are about equidistant to her house in Scotch Plains; LDJ, SMQ, N51, and 47N.
Ignoring the price of fuel and airport restaurant, which one is best for flying in and out with a few days of tie-down/hangar? John Goodman |
I'm based at Somerset, SMQ. It is a very nice, friendly airport. Ramp space shouldn't be a problem. I would give them a call if you are interested in hangar space. In and out is very easy. We have three approaches, two are RNAV. NY Tracon is very accommodating if you are coming or going IFR.
N51 and 47N are similar in feel to SMQ. LDJ is much busier and sits very close to Newark. IFR to or from LDJ you are more likely to have delays. I would guess that the ride from SMQ to Scotch Plains is about 30-40 minutes. |
Airports
Lots of horror stories about LDJ but they all appear to be from about three years ago. I personally would not use LDJ unless I wanted to go into Manhatten. 47N would be the next closest, tiedown should not be a problem, access to the highways is pretty good.
Thanks for the replies and private messages! I've pretty much decided to fly into MMU with SMQ as a second choice. Should be arriving around the 11th barring bad weather.
John |
| All times are GMT -6. The time now is 06:22 PM. |
