VAF Forums
-   -   helps on installing the canopy on the 4 (https://vansairforce.net/community/showthread.php?t=1031)
Ted Farmin 03-26-2005 10:29 PM
moved the roll frame back 2" to move the front seat back 2". removed
the cross member to relocate aft of the new location of the roll frame.
have bent the frame to match the sides of the fuss. looking for any helps
on constructing the rest of the frame. looks like the butt joint of the front
to side skin may show a bend what have some of you done? what is the best
procedure for the bend of the skin at canopy contact area?
any and all suggestions will be appreciated.
Ted
szicree 04-01-2005 07:55 PM
Here's the method I used to do my canopy skirts. It's kinda long but it worked very well.
First get all the holes drilled through the canopy and frame. Take the canopy off and stash it out of the way for a while. Drill all of the holes through the bottom of the side skirt to the canopy frame. On the hinge side, I used a few flush rivets to hold the hinge to the frame temporarily. You'll probably need to trim the bottom edge of the side skirt to match the cockpit rails, but try not to give up too much material since it might be needed at the top. I next drilled and clecoed the skirt to the cross piece. I found that the shape of the flange left something to be desired, so I cut off the top couple of inches and will graft on some angle once everything else is done. Once this is clecoed in place, I took about a dozen little spring clamps and clamped the upper skirt to the canopy frame. Don't worry about the area aft of the rear seat. Next, take a pencil and wittle the first half inch or so flat on one side. This flat side will ride on the underside of the canopy frame while the tip marks the inside of the canopy skirt. I wittled the pencil until the first half inch was showing lead on the wittled side. This way the thickness of the pencil doesn't screw up the location of my line. I tried very hard to keep the pencil perpendicular to the skin as I went so that the line would stay where I intended. I only marked to the rear of the back seat bulkhead. I then removed the skirt and made a new line with a sharpie a half inch above this one. This line is the cut line. I cut along this line and then took my time getting it real fair and smooth. This line needs to be nice because the bending tool is going to ride along it. After it was all deburred and polished, I clamped it to a table and used the Avery canopy skin tool to gradually bend the edge. You'll want to practice on some scrap first and be aware that the tool will try to ride out away from the edge. Work slowly and check the fit often. You'll want to put the canopy on for fit checking. I used a few of the AACQ rivets to hold the canopy in place while fitting. I used a strap duplicator to locate the holes in the canopy skin. For best results I ground down the stap duplicator to make it as thin as possible. Once I had what I wanted I took the whole mess apart and repeated the procedure for the aft section. The idea behind doing the aft section last is that all the bending of the main section will move the aft section around. The very tail end of the thing needs very little bend. I should add that the first skin I did got ruined because I used the Avery instructions suggestion for measuring 3/4 inch rather than the 1/2 inch that I ultimately used. Since the measurements were taken with the canopy OFF, when the canopy was put on it pushed the bend out (and up) so that the holes would've gone right through the bend lines. On the replacement skirt, I used 1/2 inch and the holes wound up going right through the middle of the flange perfectly. Once everything was clecoed together, I spent A LOT of time carefully trimming away material where the skirt meets the tailcone to get a good fit. It was very tedious, but it came out very clean. Others may have a different method, but my skirts really came out much better than I had expected based on the horror stories. Good luck and feel free to email me directly if anything needs clarification.
P.S. the Avery website has the tool on sale right now for $14 !!
Ted Farmin 04-01-2005 09:51 PM
szicree help on canopy building
Thanks for the info on installation of the canopy szicree. I have some questions but being computer illiterate and new to this site I don't see how to email to you. Also if you could email me your phone no. and a convienient
time to talk I would like to call you. tedf@sandpoint.net
Many thanks
Ted
