VAF Forums
-   -   grinding wheel material (https://vansairforce.net/community/showthread.php?t=10278)
prkaye 08-22-2006 07:58 AM
I recently bought a small bench grinder from a hardware store. I removed one of the blue grinding wheels it came with and put a 3m Scotchbright wheel on. I left the other blue grinding wheel on the grinder, thinking I can use it for more aggressive grinding tasks (like smoothing corners of parts I have to fabricate from aluminum angle).
Question - is it OK to use the general purpose grinding wheel on airplane parts? Or is there a chance that the grinding wheel will contain some metal content, and that this could get worked into the aluminum I am grinding, opening the door for corrosion by dissimilar metals?
Baja_Traveler 08-22-2006 08:20 AM
Never - Ever use a grinding wheel on aluminum parts or any non-ferrous material. What will happen is the grinding wheel will load up with aluminum, go off balance and could come apart with disastrous effect - especially if your face happens to be in the way of the flying shrapnel of broken wheel. The part you are trying to smooth will come out with a terrible finish also - having seen the results in high school shop class - the guy got lucky though when the 10" wheel exploded and nobody was hurt. He got thrown out of class for not paying attention... :eek:
Brantel 08-22-2006 08:23 AM
Grinder wheel and aluminum don't mix
Aluminum + Grinding Wheel = Emergency Room Visit :eek:
prkaye 08-22-2006 08:35 AM
Whoa - glad I asked!!
mdredmond 08-22-2006 08:55 AM
Can you use silicon carbide wheels for non-ferrous metal??
From Norton's (wheel mfr) web site:
"The Norton Bench and Pedestal Wheel line encompasses three tiers and two abrasives ? to answer all your deburring, shaping and sharpening needs: aluminum oxide for high speed tool steels and other metals and silicon carbide for non-ferrous metals."
Baja_Traveler 08-22-2006 11:03 AM
[quote=mdredmond]Can you use silicon carbide wheels for non-ferrous metal?? "QUOTE]
Yes - silicon carbide wheels are intended for that purpose, but in my machine shop experience it was used to put the fine finishing touches on dimension, not take alot of material off to shape. If you do use it make sure to keep the part and wheel wet with LPS, WD40 (I've even heard of crisco being used) so the wheel stays clean. Once melted particles of aluminum get into the wheel the only way to get it out is to dress the wheel with a carbide dressing stone. What we found in the end is that the coarser ScotchBrite wheels did the same job with alot less hassle for low tolerance work. We still used the silicon carbide wheel on the surface grinder though, but that was for precise dimension that we are not after here.
rivetshaver 08-22-2006 03:23 PM
The best tool to use for any work with not ferrous metals is a belt sander. I use a 1" wide Delta benchtop belt sander. I use coarse , medium and fine abbrasive belts as necessary for the job at hand. If a belt tears the worst that can happen is it will make some dust. Grinders are dangereous.
Paul Thomas 08-22-2006 03:30 PM
Learned something new... I haven't done it much, but I've done it and quit because it wasn't efficient.
mdredmond 08-22-2006 03:43 PM
I bought a Delta 1" vetical belt sander with the small (5"?) disk sander on the side. Seems like a good tool. Maybe I'll slap a coarse scotchbrite wheel on the other side of the grinder.
rv9aviator 08-22-2006 05:23 PM
I have a 3M scotchbrite light deburring wheel on one side and a 3M cut and polish wheel on the other side. They are both 6 inch X 1 inch wheels and do a great job. All other grinding and smoothing operations are done with air tools with assorted sanding and polishing wheels. The 1 inch belt sander is also a great tool. One little piece of advice would be if you have the little tool rests on the grinder attached keep them very close to the wheel at all times or remove them. The gap between the wheel and the tool rest is what usually gets people hurt. I see no reason to have them on for our purpose anyway. They just get in the way.
