Repairing a hole in the fuselage
I had the opportunity this week to wander around many of the fabulous RV's that were at Oshkosh. I admit to peeking underneath, seeing how one thing or another was done on your plane. I peered into planes to see what color you used. One thing I would still like to do is check out rudder locations. I'll post that request in a different thread.
This thread is for the mistake that I found out I have made. I have come to the definitive conclusion that steps are not needed on a tail wheel RV7. Unfortunately I have bored two beautiful holes in the side of the plane for the steps that I was going to put on. As I see it, I have three choices.
What I'd like to know is if anyone else has had to face this and how did they overcome it? Are there any options that I am missing? The new side skins seem like the most pain free solution, but they have already been rolled and all my holes have been match drilled, though not dimpled. |
Isn't that spot just begging for the statement that could be made by covering it with a "NO STEP" placard?? :rolleyes:
Nice idea, hadn't thought of that.
One Step Further
Scott is right on! I have thought about doing this to my steps. I would do just what Scott did but prep it for a coat of body filler to make it totally invisible. To do this I would use a .024 round circle like Scott so it sets a little low. Then after I dimple the fuselage skin, I would then countersink the dimple to make the rivet set about .001+ lower than the side skin. I can't tell from Scott's pic if he did this or not. When you put on the body filler there is no chance of anything sitting proud and thus an invisible repair. Another option is to countersink only, since it is not a structural repair.
Steve "The Builders Coach" |
Shorten step
I searched my bookmarks for a link to someone that had shorten their steps. I can not find it, probably deleted it when I filled mine. The process would be easy enough to remove the portion you step on and then reduce the over all length and re-weld the step.
Given the same decision again I would shorten my steps and install them. But I am certainly not going back to that solution now. I would like to finish this plane some day. |
Mel, got any pictures of that? I'm thinking I may want to do the same for my wife.
| All times are GMT -6. The time now is 11:56 AM. |
