VAF Forums
-   GPS (https://vansairforce.net/community/forumdisplay.php?f=39)
-   -   Garmin 396 496 running autopilot (https://vansairforce.net/community/showthread.php?t=10253)
sneedrv-6 08-21-2006 01:20 PM
I have a trutrak pictorial pilot and a garmin 496 feeding it the nema. Before I had the 496 I had a 396 with the same problem.
Everything works great except while the AP is in NAV mode if I scroll the map on the gps it will disconnect the nav mode and go into heading mode. Sometimes it does this without even messing with the GPS. I think that the gps processor is just getting overwhelmed and it stops the NEMA data for a second which disconnects the NAV mode on the AP. Does anyone have a Garmin 296 396 or 496 working correctly with a trutrak autopilot? Could I have a EMI problem? Any help would be great!
Thanks a bunch,
Jason Sneed
www.highland-parks.com/n242ds
dan 08-21-2006 02:47 PM
I see the same symptom, as well as other symptoms. Sometimes when the screen on the 396/496 refreshes, there appear to be momentary interruptions in serial output. I've been reporting these issues to Garmin, and they are working on 'em.
N130WN 08-21-2006 03:41 PM
I've also seen the same thing. I thought I was loosing my marbles, but no, I still have them.......
TT DF200VS
Garmin 396
sneedrv-6 08-21-2006 07:11 PM
update
Guys,
I spoke with John today at trutrak... He said this is a know issue and I need to send in my autopilot to have a chip replaced (update firmware). I will post here when I get the AP back and let you know if it is fixed. Even if this does not fix the problem it seems to me that trutrak would be able to tell the AP to not drop out of NAV mode unless the nema stops for some longer period of time.
We shall see...
Jason
dan 08-21-2006 07:22 PM
I sent my Pictorial Pilot in to TruTrak for the update. It came back with a longer shaft (which is great, since it can now be used with a Nulite ring), but other than that, absolutely no difference that I can detect.
sneedrv-6 08-22-2006 01:18 PM
update
Dan,
Spoke with John again, I asked about changing the code on the AP to allow for 5 seconds or so with no NEMA before it pops out of NAV mode. We will see what happens, I encourage anyone with a 396 or 496 to let trutrak know there is a problem. John is the person I have been working with.
Jason Sneed
I also tried to get Garmin to do something but I had no luck.
flymustangs 08-26-2006 09:21 AM
"Fast" rate?
Maybe a stupid question, but does this happen with the serial output in the "Fast" mode? I'm not even sure the "fast" mode puts out enough information to drive the autopilot.
Another question on the serial input/output. I can't find any reference in the manual concerning fuel input. It looks like it will output data to a fuel totalizer, though. Is that correct?
Thanks.
sneedrv-6 08-26-2006 01:54 PM
As far as I know the fuel totalizer does not interface with any other device. I have tried every setting on the interface page (advanced options) with no luck.
Jason
William Slaughter 08-26-2006 02:29 PM
Depends on the fuel totalizer? I've purchased a JPI FS450, and the literature states "Serial port sends and receives data from all GPS units, even handhelds." More info available at http://www.jpinstruments.com/fuel_scan.html. Of course it's still theoretical for me at this point.;)
CraigH@KRPH 08-26-2006 03:34 PM
Just hooked a JPI-FS450 to my Garmin 296 and gave it a test hop this morning. Works great!
