AFS 4500 and ADS-B
Anyone know if there's anything in the pipeline that would provide ADS-B for the 4500 series EFIS from AFS?
They have a module available for the current series but I don't see anything that is backwards compatible. :( |
I have had it installed for over a year now. |
me too!
Running my AF4500 with the Navworx unit - works very well!
Me three
I have the Navworx as well, it works well with 4500 Larry
What about the FreeFlight ADSB?
Anyone flying this with the 4500s? The company told me that it will work and they are being used with the 5600 But I have had some suspicions ablout compatibility because some answers seemed vaguel Could go with NavWorx if I had to but is much more expensive. Glenn Wilkinson |
You can use the Freeflight or NavWorx unit with the AF-4500.
The Freeflight is an ADS-B receiver only and will not display traffic unless you have a Mode S ES transponder (ADS-B out). Rob Hickman Advanced Flight Systems Inc. |
| All times are GMT -6. The time now is 10:14 PM. |
