Carburetor Fuel Inlet Fitting - MA4-SPA
For the engine and carb gurus here:
I have a Marvel MA4-SPA carb on my O-320E2D. The engine and carb used to be on a Skyhawk and will live out their useful lives on the nose of my RV9A - a far more worthy cause. In trying to figure out what sort of fitting the carb fuel inlet (fitting with finger screen) would accept, the closest thing seems to be a standard AN6 threaded fitting with 1/4" NPT thread. However even lubricated with Permatex #2 the NPT fitting doesn't "feel" right going into the finger screen fitting. It gets quite tight only a single turn or so into the finger screen fitting. I'd heard elsewhere (maybe here on VAF) that these carbs might need a NPSF threaded fitting. Not sure where to get one of those with AN6 on the other end. I did try the fitting with o-ring that fits into a Lycoming fuel pump and had no success. It's clear these are incompatible with the finger screen inlet threads. Ideas? Am I being perhaps too gentle with a standard steel AN6 fitting with 1/4" NPT? |
fitting
I have a copy of an old Aviation Maintenance Technology article from when Facet supported these carbs. One picture clearly shows an AN822-6 fitting in this location. I am going to investigate this further but as of today I plan to use the AN 822. A 1/4" pipe tap bottoms out in the hole in the carb fitting so it may be a matter of manufacturing tolerance on the AN 822.
The gasket for the strainer fitting is all metal, a Marvel Schebler part number that is available from Aircraft Spruce. |
This is a common issue. Although not recommended, an aluminum fitting will seat okay in the finger strainer fitting. I ran my steel AN6 fitting through a 1/4" NPT die and was easily able to take the fitting down enough to get what I thought was a reasonable number of threads engaged without worrying about bottoming out.
deek |
Thanks, all! I took the finger screen fitting out of the carb, chucked it lightly in a vise, and torqued a standard steel AN-6 threaded elbow, with Permatex #2 sealant, into the fitting to the proper orientation. Re-installed the fitting assembly with a new crush washer into the carb body. It seemed to go in okay - we'll see in a few months whether it leaks or not.
Thanks again to all who responded! |
| All times are GMT -6. The time now is 02:22 PM. |
