VAF Forums
-   RV-8/8A (https://vansairforce.net/community/forumdisplay.php?f=6)
-   -   PC680 vs PC925 in RV-8 (https://vansairforce.net/community/showthread.php?t=100719)
Airzen 06-11-2013 04:47 PM
I will have rear mounted battery and it seems like PC-680 is far more popular in RV-8s than anything out there.
However, I am also reading posts where several RV-8 builders have had issues with CG being to far forward. Consequently, I am wondering if it makes sense to consider 10lbs heavier PC-925. It looks like it'll make CG go aft around 0.5 inches, plus added benefit of more capacity.
Has anyone considered PC925 in RV-8?
To give you an idea, I have IO-360 with constant speed Whirwind 200RV, raven inverted oil and glass instrument panel. ELT and Strobe Powersupply are mounted in rear fuselage.
Any opnions/suggestions?
DanH 06-11-2013 05:00 PM
Yes, I use one. Helps the solo CG (390 and Hartzell BA), and the extra capacity (cranking and endurance after alternator failure) is nice. Fits the stock battery tray when mounted on its side.
Airzen 06-12-2013 09:35 AM
Thanks Dan.
I hope you wont mind me asking a couple of more follow-up Qs.
1) Whats your CG with the configuration you mentioned?
2) Is it favorable for Aerobatics?
3) Any idea how heavier IO-390 is when compared to IO-360?
chris mitchell 06-12-2013 09:37 AM
Alternatively, add lightness at the front. :D
You already have a light prop. Use a gear-driven alternator and a lightweight flywheel/starter ring. The added benefit is that there is no alternator belt to break. I'll be doing just this in the RV-4 that's now lurking in my garage.
The PC 680 is 10 lbs lighter. A lightweight flywheel is only 2.95lbs. Standard flywheel weight??? but a lot more than 3lbs!
Chris
Andy Hill 06-12-2013 10:17 AM
Parallel (180HP) or Angle (200HP) valve variant? Makes a lot of difference :eek:
Whatever, I suspect the Whirlwind means Fwd Battery probably best bet, and certainly not a heavy rear Batt. Conversely, a 200HP with Hartzell likely needs all it can in the rear.
Airzen 06-12-2013 10:32 AM
details
I got
- IO-parallel valve (180 hp)
- Sky-Tec Light Weight Starter (7.8lbs)
- Plane-n-power altrenator (6.5 lbs)
PS Chris: Not sure I can shave more off the nose without going to automotive starter as you mention (and I am not confident myself to do those kinds of mods As for alternator, I think at 6.5 lbs its already pretty light.
PS Andy: you might be right, thats why I am seeking info.
DanH 06-12-2013 01:06 PM
Originally Posted by Airzen (Post 778852)
Thanks Dan.
1. More to that question than just engine/prop choice.
2. Heavy pitch forces when solo. More pleasant to fly with a passenger, which was the primary mission goal.
3. They say 8 lbs.
Saville 05-08-2016 02:17 PM
I'm looking to install a PC-925I would like to install a PC-925 in my RV-8. But the only way it will fit in the standard aft compartment battery tray is if I set it like this:
Closing the door will short those lugs.
When you say "mounted on it's side" which direction did you have the lugs face?
The battery came with smaller bolts which fit the smaller diameter thread in the battery itself, and have no upper, wider diameter, lug.. That will keep the lugs from hitting the metal door.
In addition, I'd line the door with rubber just in case.
But I'm wondering if the smaller bolts, along with a lock washer, will stay tight?
thanks
longline 05-08-2016 06:17 PM
Saville
I installed a PC925 in a C-190 years ago. Those 8mm bolts were never, ever, an issue. They stayed tight until they met a wrench. There was more than just a little vibration involved with this aircraft, too.
This is a superior battery. I am using dual PC680 batteries in my RV8, which has yet to fly.
Naturally, the cable termination was different than standard, but we do not need to worry about that in experimental aviation.
Saville 05-08-2016 07:36 PM
So you went with a cable end that had a smaller hole?
What was the order of stacking?
flat washer, cable, flat washer, lock washer?
Or cable, flat washer, lock washer?
thanks
