VAF Forums
-   -   a couple printed ideas (https://vansairforce.net/community/showthread.php?t=147771)
Tom Delaney 08-31-2021 07:49 PM
Originally Posted by rocketman1988 (Post 1552564)
Will that bogi bar holder work in a -10?
Hope so! Hoping to find a solution.
Steve Melton 08-31-2021 07:52 PM
negative ghost rider, this is dedicated to the 14 only.
rocketman1988 08-31-2021 08:07 PM
Any chance
Any chance of making a version for the -10?
Steve Melton 09-01-2021 06:39 AM
the 10 has a different bulkhead screw arrangement. are you willing to drill dedicated bracket screw locations in the removable bulkhead? if so, I could take a look at it.
rocketman1988 09-01-2021 07:28 AM
I think so...
I guess my question is if the corrugated panel is the same in the 10 and 14. If so, I would think that the 14 unit would work but the mounting holes would be in the panel only, as the 10 has just one vertical support, and it is just off center...
rocketman1988 09-01-2021 07:36 AM
bulkhead
1 Attachment(s)
Here is a picture...
Attachment 15305
Steve Melton 09-01-2021 07:49 AM
this is correct. the idea of drilling new holes in bulkhead for the brackets needs to settle. the nice thing about the 14 mount is that it uses existing holes.
another option for the 10 that uses existing bulkhead holes is the wag-aero brackets and tow bar. I believe the wag-aero tow bar with a posilock makes a good traveling bar because it is very compact when stowed. just leave it in there. nice to have options. the wag-aero tow bar also is low cost.
what I was finding is that when I thought I would need a tow bar, I didn't. when I didn't think I would need it, I did. now it's always there, up and out of the way and accessible. when parking at an FBO I sometimes throw the bar under the plane in case they need to move it. many times they don't have bars for RVs. put your name or aircraft number on the bar.
Bavafa 09-01-2021 09:04 AM
Hi Steve,
Do you think you can make the kind of arms that gets attached to the rudder pedal for trim, something similar to this
https://www.aerosportproducts.com/product/rudder-trim/
Steve Melton 09-01-2021 04:10 PM
Originally Posted by Bavafa (Post 1552665)
Hi Steve,
sure I could make something close to those from nylon and carbon fiber but why don't you just buy the ones from Aerosport? seems that they have put together a package for a reasonable cost.
rocketman1988 09-01-2021 04:55 PM
Tow bar
Ok…no worries. Already have the bogi bar. Very difficult to move the -10 by myself without the tow bar.
Just thought it would be easier to use one that is already available…
