VAF Forums
-   Tip up canopy vs. Sliding canopy (https://vansairforce.net/community/forumdisplay.php?f=55)
-   -   Showplanes RV-8 Fastback Canopy Questions (https://vansairforce.net/community/showthread.php?t=188370)
Gusmax 10-28-2020 02:42 PM
I'm building a 200HP Rocket and LOVE to composite canopy kit that Showplanes sells for their fastback conversion! It is a work of art. Unfortunately, it will not fit the Rocket canopy. I'm considering making something similar for my plane and I have a few questions for those that have installed one of these kits, or hopefully the maker of this beautiful kit;
1- How thick is the core material on the side skirts and cross supports?
2- How thick is the glass at the edges where there is no core material?
Here is a question for the engineering folks on the forum. Would carbon fiber be a suitable reinforcement for the canopy frame since it seems to have practically no thermal expansion rate compared to regular glass fibers? I'm concerned about the acrylic expanding much more than carbon and causing cracks in bubble? There must be many high end sailplanes out there with large canopies with CF frames?
Thank you for any help!!
Phil
vfrazier 11-02-2020 12:41 PM
Phil,
I inquired with Bryan Milani about getting Showplanes to produce a version of their canopy for us.
If you, or others, can make it happen, I'll gladly add their fine canopy set up to the mix.
Bryan, we're serious.
Gusmax 11-02-2020 01:58 PM
Hi Vince,
I thought most were going for the slider canopy?
