The pieces can break off the edge of the cam lobes after the followers become concave (if they are not rollers) and create edge loading. Lots of speculation - a good magnified photo should narrow the scope. Something is definitely happening, but just when it needs repair is not clear yet from information available. |
Power?
Bill,
If the lifters were out of range, would that affect performance? The engine has been running like a champ. I'll see if I can get better pictures of the particles and maybe get them analyzed. I hate to start performing exploratory surgery unless there's no other choice. -Matt |
I'll restate, ferrous chunks of that size need to be identified as to there source so that you can assess your risk. Larry |
Martin.
I can give you two cents from the peanut gallery. Pictures are sometimes hard to read and inturpret so from what you have posted I can guess but not be sure. The dark black stuff looks to be normal coke and stuff you see all the time. But the metal that is both in the finger strainer and on the magnet is a dead giveaway there is something in the engine going away. If I understand this history of this power plant correct, it has been stored from time to time and not run for months at a time. What you are seeing is what we would expect for long dry store, start damage. It is better to pull a jug or two now than wait or guess if or when something may turn loose internally in this power plant.
Sorry, I think you need to get this stuff checked and identafied then if it looks to be gear, cam, lifter or whatever metal go in and put your finger on the problem. You will be money and peace of mind ahead. Hope this helps, Yours, R.E.A. III #80888 |
Making Metal
I was putting together a comment but Robert Anglin very clearly stated what I was thinking. Have dealt with this issue a several times and his advice is spot on.
Don Broussard A&P, IA etc etc RV9 Rebuild in Progress 57 Pacer |
I hope your results are different than mine.
For the last year I've been seeing metal in the filter on my RV-10's io-540. I found one small shard in my pick-up screen. All told, less metal than you are picturing. I had my mechanic look at what I found and he wasn't too concerned. My oil analysis always comes back normal. For piece of mind, I pulled my #3 cylinder since there was some evidence of past corrosion in there. The cylinder looked as expected. However, the tappets I could see had severe pitting and there was visible cam damage. My engine is at Barrett as we speak. My cam and lifters are shot. There is some scoring on the crank which may or may not polish out. I should have stopped flying it earlier--it may have saved me the cost of a crank. My engine came off a Piper Twin, and then only flew 200 hours in 7 years in my RV-10 before I bought the plane. I knew I might run into this, but I was hoping not! Best of luck! Guy |
As to the question on loss of performance on the worn cam, I doubt you would notice anything. I have a Mustang 2 with an O-360 that I bought about 5 years ago and prior to my buying it it sat for a while and apparently got some rust on the cam which is all it takes to ruin one. Engine ran just fine until a minor prop strike and I pulled the engine apart to magnaflux the crank. I was shocked to see two cam lobes with nearly an eighth inch of wear on the end of the lobes and correspondingly ate up tappet bodies. I expected a nice increase in performance when I put the new cam in, but two engine experts said I probably would not notice any difference and I could not even tell when I flew it. And this is a plane that I keep detailed performance records on.
Sharp Pointy Particles
Here's a better photo of the particles on the magnetic drain plug.
![]() I'm planning to pull the #2 cylinder when I get a free weekend. That one had the lowest compression (72) on the last annual. -Matt |
If you happen to have a buddy with an analyzer to determine the alloy of the fragments, Lycoming can tell you where the metal is coming from. They offered to do this for me when I was making small metal and couldn't confirm the source. I later figured out it was aluminum and never used their service. My piston pin plugs were wearing away. Larry |
