VAF Forums
-   -   a couple printed ideas (https://vansairforce.net/community/showthread.php?t=147771)
Steve Melton 06-20-2018 09:49 PM
PC80 battery tray
a good fit. no, an exact fit!
rv7charlie 06-20-2018 11:01 PM
So, will it get bigger at the same rate as the battery case, as things heat up?
Steve Melton 06-21-2018 05:51 AM
what is the temperature rise of this battery above its environment?
rv7charlie 06-21-2018 06:42 AM
I was really talking about environmental changes; same issue as canopy vs frame expansion rates cracking canopies. But you're right; charge/discharge rates can heat a battery, as well. I was kinda joking about the 'perfect fit' phrase, but if it's really a tight fit, could expansion pressure damage either the case or the tray?
Steve Melton 06-21-2018 06:45 AM
it has about .030 inch clearance on the width and .020 inch on the length.
n981ms 06-21-2018 07:02 AM
Somebody might want a tab sticking out of your tank cover that would function as cap removal tool. It would detract from the simplicity and symmetry but add a touch of functionality.
Steve Melton 06-21-2018 11:19 AM
thx, I'll keep that in mind as a future option.
azflyer21 06-21-2018 11:44 AM
Tip up handle
Steve,
Just a suggestion, a handle for the tip up canopy would be a nice addition to your product line. Something to fit the C-01405C.
Snowflake 06-22-2018 09:07 AM
Kevin, your photo doesn't show up.
Steve Melton 06-22-2018 04:31 PM
I could see the picture earlier but cannot now. My neighbor has a 14 so I'll take a look at it. thx for the idea.
