VAF Forums
-   -   a couple printed ideas (https://vansairforce.net/community/showthread.php?t=147771)
Steve Melton 05-10-2018 09:57 PM
cool beans. thanks passed along to Amanda.
Originally Posted by Vlad (Post 1259154)
Got all the goodies Steve pass thanks to Amanda nice job! Will install tomorrow. Let's see how they survive the beating. Will report here after first thousand hours on them :D
Steve Melton 05-28-2018 08:34 AM
fuel vent cover - slip on
could be an option for Summer flying to keep the big bugs out.
slip on fuel vent cover
rv7charlie 05-28-2018 10:05 PM
Certainly *looks* cooler than my little discs of aluminum window screen, prosealed on my vent openings. Not sure it would be as effective, though. We have bees & wasps in my area that are quite adept at plugging a 1/8" hole.
Charlie
Steve Melton 05-29-2018 06:00 AM
if it is plugged, pop it off, throw it away, put on another and go.
rv7charlie 05-29-2018 08:13 AM
You must not have the same critters in your neck of the woods. The ones down here start building several to many inches up the tube, and work their way out.
Besides, the whole point is to avoid the plug.
Bill Boyd 05-29-2018 08:58 AM
Not sure about Mississippi mud daubers, but I've found their Virginia cousins are completely stymied by a piece of safety wire bent in the shape of a large bobby pin (for friction retention) and shoved into the pitot tube. Easily pulled on preflight like a dipstick to check for mud/bug guts - but I never see any.
Like Charlie I have screen mesh over the fuel vents, but I think the wavy safety wire trick would work as well. I had several instances of aborted takeoffs due to invisible wasp clogs in the pitot before I did this. Fuel vents had screens from day one.
Steve Melton 05-29-2018 11:11 AM
screens and this plastic piece can freeze in the Winter. Better to have it open in the Winter.
Charlie
Steve Melton 05-30-2018 11:34 AM
proto1 tested. no change to fuel pressure observed with half tank.
proto2
aparchment 05-30-2018 01:23 PM
Screen insert
Steve,
For those who are concerned about smaller insects, they could also embed a micro screen between the plastic and the vent fitting.
laz 05-31-2018 09:17 PM
when will these be available
