SOLD: Oxygen System
czechsix
$300 + shipping.
Sale includes M-22 aluminum oxygen bottle (22 cu. feet or 623 L capacity) made by Catalina Cylinders. Manufacture date 01/2002. Fitted with SkyOx 4-place regulator. Comes with two SkyOx connectors (quick disconnect fittings that plug into the regulator) and hoses that connect to the cannulas (you'll want to buy your own cannulas of course, this system was used with Oxymizer nasal cannulas which are under $50 new, but should work with other brands/styles as well). If you want to use it in a 4-place aircraft you'd need two more SkyOx connectors which are ~$60 new.
Currently the tank has a full O2 charge, unfortunately it will need to be emptied before shipping unless you happen to be in the KC area and can pick it up in person.
