For those that used a clear coat over dry transfers, what clear coat do you recommend?
Webb Well Known Member Sponsor Dec 7, 2022 #1 For those that used a clear coat over dry transfers, what clear coat do you recommend?
carlrai Well Known Member Patron Dec 7, 2022 #2 Recently used this over dry transfers Eastwood polyurethane matte, clearcoat. 3 Very light dust coats, 15 min between coats followed by two more medium wet coats. Came out beautifully. A bit spendy but worth it. https://www.eastwood.com/eastwood-s-2k-aerospraytm-high-gloss-matte-clear.html
DanH Legacy Member Mentor Dec 7, 2022 #3 PPG Shopline has held up well, about 12 years now. Sprayed 3 or 4 coats, cured, block-sanded wet over the lettering with 400, one more cross coat. .
cajunwings Well Known Member Dec 7, 2022 #4 DanH said: PPG Shopline has held up well, about 12 years now. Sprayed 3 or 4 coats, cured, block-sanded wet over the lettering with 400, one more cross coat. . Click to expand... I’m closing in on finishing the panel. Does PPG refer to it as Shopline Clear Coat?
DanH Legacy Member Mentor Dec 7, 2022 #5 cajunwings said: I’m closing in on finishing the panel. Does PPG refer to it as Shopline Clear Coat? Click to expand... You're in luck...it was still in the paint cabinet: Attachments IMG_20221207_122156959.jpg 76.7 KB · Views: 32
Majorpayne317641 Well Known Member Dec 7, 2022 #6 Rustoleum rattle can enamel matte clear coat. It turned out great.
