FlyingDiver
The instructions on this page are not as clear about the intended result as I would like. If I'm reading it right, I just need to remove a small amount of material from the center rear of the plexiglass to make sure that the plexi doesn't actually touch the F-1232B-L & -R (1/32" clearance) when the front edge of the plexi is at or slightly in front of the rear edge of the F-1231A-FL & -FR Roll Bar Frames.
There doesn't seem to be anything in there about trimming the front edge of the plexi to get an exact match to the front frames. And, as far as I can tell, only the area right in the center of the aft edge needs to be trimmed.
Is that right?
Also, what is the purpose of the tape in step #15? I don't see it being used at all in this section.
Is that right?
